Tire size conundrum
Well the thing I don't know for sure is how badly the electronics might react to the smaller wheel diameter, and don't really want to waste money on "incompatible" tires. On pre face-lift models it's apparently not a big deal according to some threads, and the wheel size change in the computer is quite easy and painless (within some limits of course of supported wheel sizes, but there are usually way more sizes programmed than just the two oem sizes for this specific Octavia version, at least according to VW threads). Although looking at octavia spec the smallest oem wheel is the 205/60 r16, and that's 1.12% smaller than the 225/45 r18 - so quite close still, and it may be that the computer/clusters don't have a small enough tire circumference profile available even if it was possible to modify those settings. I assume that that setting, as it's exactly what the Authorized Service Center changes when changing tire size within oem options, propagates to all the modules that need this information, as even within the OEM tire sizes, they span from 205/60 R16 with 652mm circumference, all the way to 225/40 r19 with 662mm circumference, so over 1.5% difference - still possibly significant for all those advanced electronics, assists, radars etc. So unless the dials module has some Golf profiles in there, this may not be possible at all, and an experiment will be necessary. Thankfully that can be done as soon as sfd2 get's unlocked, without the need to physically swap the tires, as the setting change will change the indicated speed, and that's enough to calculate what circumference each profile corresponds to. Would be nice though if all of that was just openly available in the user manual for the car. Or perhaps some "advanced user" manual - optional.
GordoGT started following Retrofitting flat MFSW with DSG paddles to an 2013 Octavia questions
Mpg????
Our 1.2 TSI 120 bhp DSG will easily do 55 to 60 mpg on a 50 mile motorway journey at 70 mph. On short local journeys 3-5 miles mainly urban dual carriageways 45-50 mph does around 45 mpg.
What engine for a Skoda fabia estate?
Cant advise on the Diesel, but our 1.2 TSI 110 bhp DSG 5 door hatchback will easily do 55-60 mpg on a 50 mile motorway journey at 70 mph.
Tire size conundrum
@Mariosti I thought you started out bothering about splashing some cash on tyres that cost a bit more for winter use,. now there is this stuff about different wheels, weight saving. You seem to have all the answers and knowledge so seems funny you asked in the first place.
the truth about electric cars
Quite possibly...
Definitely... The cable doesn't go to the house and stops mid air.
Or a high vehicle such as a bus were to hit it?
Maybe it has not. On their property might be ok but above the payment i doubt is ok. If the were at 4m or 5m or so at the property boundary it still would not be very safe is someone was carrying a ladder along the payment like a ladder in the vertical.
Tire size conundrum
Pretty sure no warranty covers tyres or any consumables on the car like brakes, fluids, oils, filters, shocks, suspension joints etc. Additional insurance "warranties" may cover, or partially cover such things, but that's quite some extra money upfront each year, especially on a brand new car. Sorry to hear you got so unlucky with the flats lately. I'm quite certain that if you bought a spare wheel and put it in the boot then you wouldn't get flats anymore ;) As to the unsprung weight, I am replacing the 18" skoda comet rims that are 13.2kg each according to Skoda with jrwheels SL01 18x8 , that should weigh around 8.3kg each, so that will be already a huge reduction of almost 20kg of unsprung mass on the car, but if it would be possible to remove additional 4-6kg and also get same premium threads but cheaper - well that would be a win win scenario, and certainly can't hurt also the daily driving. As a matter of fact i planned to get 5 rims and tires, to get a full size spare wheel. As I understand it should fit in the spare wheel well, and the canton sub should fit inside of the rim, or am I mistaken? Going back to the main topic, indeed, the circumference difference is too big for daily use, considering all the electronics on the car.
afarak joined the community
@lol-lolcan't believe that has been approved.
- 1.0 Tsi misfire on cyl 3, p303
- Mib3 Map Updates 2026.06
oggy997 started following Mib3 Map Updates 2026.06
Ongoing project
Wow. Those results are fantastic.... Very impressive!
TJSTJS started following 1.0 Tsi misfire on cyl 3, p303
1.0 Tsi 3 cylinder in a mk3 Fabia. 2018 reg with 110,000 miles. It's run perfectly for 4 years until last week when it started misfiring when under heavy load. Cleared all the codes and drove it. Code p303 came up, misfire on cylinder 3. I swapped the coil packs over between cylinders 2 and 3 and went for another test drive. No misfire and no fault codes. Very odd. There was a bit of oily mess on the boot on pack 3. Could that have been the issue? Or will it come back? Is it worth replacing the coil packs?
Constant app updates
When I had my recent problems I was told by the technical team that they have an update that would cure it. They would send the update to the local Skoda dealership who would install it for me. Only problem was that the dealership wanted £200+ to do the update.
I raised these constant updates with Skoda UK yesterday, to be told today "Our technical team has previously applied a general solution to prevent the reappearing software update for all affected vehicles. As the notification about the update keeps appearing in your vehicle, we would like to additionally investigate this situation with our experts. Please provide a phot of the update notification in the Infotainment system for additional analysis. We apologize for the persistent technical difficulties and appreciate your understanding." I've since sent photos of the first basic message asking me to update the software, and then ones describing what will get updated, and also one showing my car's software levels. Not sure what this will do though apart from confirm their fix hasn't worked on my Karoq!
Advice on update 0334
I have finally sorted out my problem. After trying numerous things which resulted in various messages on the screen about timing out/ failed to connect/ try again later etc. I created a new email address, which I will use exclusively for the car. I then went to the Skoda ID portal logged in and changed the email address to the new one. Next I went to the My Skoda app deleted everything. Then uninstalled the app. Reinstalled the app with the new email address and password. Went to the car deleted all user information, then registered with the new email details. It then allowed me to become primary user and all my Skoda connect details were again available Glad that I didn't pay Skoda the £200+ that they wanted to sort out the problem.
Mk2 Octavia underside maintenance
Zinc primer is of dark grey colour (at least high purity zinc one), zinc-aluminium primer is light grey to silver. So choice of colours is rather limited unles you coat the zinc layer with paint. Personally, I'm happy with the underside of the car being 50 shades of grey ;)
mntvs joined the community
Nope, no more notifications, thats blank now.
P0299-Underboost-2.0TDI 110KW DSG
05L253019F
Turbine overboost in most cases is indeed related to stuck geometry (vanes) or a malfunction of the actuator (its vacuum/electronic parts or the N75 control valve). Since your car is under warranty, your main goal is to correctly record this defect for the official dealer so they don't dismiss it as an "accidental error." On a 2020 Skoda Octavia 2.0 TDI (likely an EA288 or EA288 evo engine), the engine control unit (ECU) uses the modern UDS protocol. In Car Scanner, these sensors (PIDs) are well-defined. 1. Which Sensors (PIDs) to Select in Car Scanner: Connect to the car, select the correct connection profile (Skoda OBD-II / MQB), go to the "Live Data / Graphs" section, and select these specific parameters: Engine RPM: Engine RPM (rpm). Gear: Target Gear or Current Gear (crucial to see the exact moment of the DSG shift). Target Boost (What the computer requests): Charge pressure: specified value (measured in hPa or mbar). Actual Boost (What the turbo actually delivers): Charge pressure: actual value (in hPa or mbar). Actuator Position (Crucial for the dealer): Positioner for charge pressure actuator: acknowledgment or Activation of boost pressure control valve (measured in %). 2. How to Correctly Record the Log (Driver's Guide): You must record the log under high engine load to force the turbo to peak boost. Find a safe, straight stretch of road (ideally a highway or a slight uphill slope). Move the DSG gear selector into Manual mode (M). Engage 3rd or 4th gear. Slow down until your engine speed drops to 1500 RPM. Press the "Record" (Play) button in Car Scanner. Press the accelerator pedal 100% to the floor (Wide Open Throttle). Do not press it past the kick-down click, so the DSG doesn't automatically force a downshift. Hold the pedal down until the engine reaches 3800–4000 RPM. At this point, shift up to the next gear (e.g., from 3rd to 4th) while keeping your foot heavily on the gas, and continue driving for another 3–4 seconds. Stop the recording. 3. What to Look For in the Log for Your Warranty Claim: Export the data as a CSV file or look at the graph in the app. The smoking gun for a faulty VNT geometry/actuator on a 2.0 TDI will look like this: As RPM rises, the Specified Boost stabilizes (e.g., at 2500 mbar). The Actual Boost shoots way past it up to 2900+ mbar. The Actuator Position (%) drops to its minimum threshold. This proves the ECU is trying its hardest to open the geometry and dump the pressure, but the actual pressure won't drop because the mechanism is physically jammed. Immediately after this layout occurs, the car will throw a glow plug light (coil) or Check Engine light on the dashboard and enter Limp Mode. Take this graph or CSV to your official dealer. They will be forced to run a guided actuator test on their ODIS diagnostic system and will most likely replace the turbocharger or the electronic actuator under warranty. Once you record the log, let me know: Were you able to capture the pressure spike on the graph? What specific error code (e.g., P0234) did Car Scanner read when it happened? Feel free to share the peak values (specified vs. actual) here for a quick analysis!
WinMan started following P0299-Underboost-2.0TDI 110KW DSG
Marekbub started following Trunk rear light
Trunk rear light
Hello, it is pouring a little water into my trunk rear light. I am planning to unmount the light and try to seal it with silicone glue. My question is, if I open only the trunk during the replacement: Will I need diagnostics run after I fit my light again? Will there stay any warning/error on my infotainment. Will my dynamic blinkers run again?
- Software update, which software?
