Past hour
Play in between outer and inner track rod end
Rum4mo The looseness appears to be between the track rod ends! Just to right of locknut in photo, but lock nut is done up tight. QuoteWhy does it look like the TRE lock nut is not bearing up tightly to the TRE end? Mechanic said you can get your nail in that gap as it opened and closed, but I've had a go at tightening lock nut with wheel off ground and it is tight. That photo was taken before getting home so maybe it did tighten up slightly. Kwik fit assured me if lock nut was loose I'd quickly get adverse symptoms with steering...
Mine is just about on 4 years and working fine. The car is often left sitting in the garage unused for several days at a time so I always keep it 'trickled' on the CTEK charger with the car locked (to assure full shut down).
SouthernComfort started following How are your EFB batteries holding up?
- Play in between outer and inner track rod end
Bonnet support clip come away
One final thing, the correct part number for cars built up to 15/05/16 is 1U0 823 397, and the correct part number for cars built from 16/05/16 onwards is 6V0 823 397. I don't have any reason to consider that there is much of a physical difference - but the part number was changed for a reason. Also 1U0 823 397 was changed to 1U0 823 397 121 Rapeseed yellow at 01/08/22 and 6V0 823 397 was changed to 6V0 823 397 121 Rapeseed yellow at 01/10/16
Who’s run a 4WD without the rear differential?
I need to take mine out to get it rebuilt - Octavia Scout 2015 - and according to Google, if I take out the diff and prop, but leave the CVs in the hubs, it should be ok. Has anyone done it for long? Has anyone got a good spare diff in the uk midlands
Haldex versions
Did you have any luck? I know a guy in Wales I’m going to get to rebuild mine (2015 Scout TDI). I’m not very near Wales though, but I trust him.
Fabia VRS LE Register Part Trois
419 checking in 🫡
Battery issue or?
Drop is normal to 9V when cranking.
imart143 started following Battery issue or?
barn find felicia pickup.
Got a deal on disks and pads so they're in the post as well, but they won't go on till it's driving, it can live on lipped disks and cracked pads for now. I still hope it's going to just come together in an almighty RUSH and go down the road and MOT first time.... but also I'm insane, so...
1.2 TSi CZJC Lumpy, stalled, wouldn't restart
Great result, I didn't post to this thread as I had nothing useful to offer seeing as my wife's 2015 VW Polo 1.2TSI 110PS, ie the "D" version is still running perfectly at over 61,000 miles. Your sister's car's engine was built in the "production period" where the high pressure fuel rail retaining bolts torque was suspect due to an assembly line tooling issue - do you know, if it was bought used, if the bolts had been checked or replaced and torqued correctly prior to her buying it? My wife's Polo seems to have been built just months before this engine build error. They are very "pleasant" engines to have in a small car.
Today
Software Update available for Bolero?
I didn't find one newer than 1800.
The thread on the inner TR is in the steering rack - so is the inner track rod tightened up correctly to the rack - or has its ball joint failed - which brand of parts were used. Surely, with an assistant you can work out which end is causing this problem. Edit:- I hate working on cars when it is near freezing - crap happens though!!
Just got some new tyres Michelin ps5 for the fabia that were in black Friday deal. Tyre fitter noticed 3 to 9 o'clock play across tyre on front left wheel. Showed me it moving near lock nut which was tight. Fitted inner track rod ends 55k ago but both outer track rod ends had split on rubber. I fitted lemforder outer TREs and new ball joints then wheel alignment. March 2025. The play seems to be the thread holding the outer and inner TR together. So, do I just replace 1. inner and outer TRE? Both sides inner tre and outer tree? Do both sides and think about new shocks and springs, top mounts, drop links (55k miles, 9 years on) in case shocks are problem. At 65k last shocks were toasted but suspect due to previous owner. However on our watch rear shocks were hitting bump stops after 30k miles. Don't you just love doing these jobs in the cold 🥶 If 3. Other than a dealer where should I get all fasteners for the strut? Thanks Ps same number of threads visible on both track rod joints on both sides of front axle.This pic shows the affected side but really doesn't show anything unless you watch video
bmbmdmb started following Play in between outer and inner track rod end
Battery issue or?
More likely to be the drop in battery voltage during cold crank - then the voltage recovers when the alternator kicks in.
Warrior193 started following Battery issue or?
Radio cutting out new starter motor
Reporting back The add-on hardware for radio did not work. Incartec 10-602 was fitted and had no effect on losing the radio's power. Returned. Incartec said try 10-603 which is for start stop vehicles and has capacitors. Upon switching on ignition the radio behaves as if it has been disconnected for a long time. The presets are lost and the time. Volume is set at default. On cranking it maintains power to radio but having lost most of the functions on ignition on, it is pointless. Don't know if this is a faulty old stock (it contains capacitors), but I'm returning. I'll put up with radio cutting out. Breezy Pete - ferrite connectors. Do you think these are still worth trying? Thanks
Rieger Rear Diffuser?
Yep, was a little while ago that I fitted it (and it's seen off two minor rear-end shunts in that time... and still no issues 😊) - what are you looking at?
Ads230 started following Rieger Rear Diffuser?
Since 1800 was released for sometime, is there any new software update for bolero newer than 1800 version?
darushah started following Software Update available for Bolero?
Garage Labour Time Per Job....
Hi everyone Sorry for the delay in updating. I've had the response from the garage to my query about the number of hours I was charged for replacing 2 CV boots. It seems I did well only being charged 2.50 hours per side and not their current book time for the job of 3.5 hours per side. They explained the significant amount of dismantling required when replacing CV boots, which includes removal of components such as the wheel, brake assembly, driveshaft and associated suspension components to allow the driveshaft to be removed and the CV joint accessed. The joint then needs to be dismantled, cleaned, re-greased and reassembled before everything is refitted and checked. Apparently their book time also includes the time used when preparing the estimate and invoicing for the repair! What is it that surprises me most? I've dug out the service history/invoices to see what work has been carried out over the 8 years I've owned the car. It seems both CV boots were replaced 3 years ago (17,500 miles ago) at a garage I previously used before moving area. Although I don't recall them being replaced, the invoice shows the total labour time charged for the the job on that occasion was just 2.40 hours (both sides not per side). This included replacing both ball joints. Interestingly, the CV boots themselves cost £10.00 per side 3 years ago, as opposed to nearly £65.00 this time around, with the invoice showing one side was more than twice the price of the other (£20 v £44). The bottom line is this month I was charged over £500 to have 2 CV boots replaced on my Fabia.........Gulp! ☹️ Oh well, we live and learn. To Alasdair....Thank you for your suggestions and advice. Unfortunately the car's still pulling and the steering wheel still off centre. It's booked back into the garage to be checked but the earliest they could get it in is next Monday. Thank you everyone for taking an interest in my post.
Battery issue or?
I have noticed that at odd times a couple of the assistance features aren't immediately available but they appear after a few seconds. I suspect its moisture on the radar sensor and the moisture/condensation on the windscreen.
thamestrader started following Battery issue or?
Swint started following Skoda Karoq Guides
No. You have to pop glass out then there’s 2 tabs to release mirror cap. Done it plenty of times and now got the proper vag (copy) wedge tool to make it even safer to do. But you have to told glass right down on the adjustment first which with powered ones you can’t do manually.
Great news!
I understood that the mirror cap can be taken off relatively easily without removing the glass?
Hey all, Too many people don't ever come back to a thread to update on how/if the problem was solved. I'm delighted in this case to report the problem is solved, which means peace and quiet for me from my sister too. The camshaft adjustment solenoid / N205 /camshaft actuator / vvt solenoid was the problem. I took it out last night and the gauze was missing/damaged as per a VW tpi given to me by a kind VW master tech. 1 T30 bolt is all that stands in the way of this actuator being removed (plus electrical connection on top) and then you can get it out. Popped a new one in today and I've not felt the level of anxiety induced pre engine start in a long time. Only went and started up, settled down and sat running until coolant was warm. Out driving, power has been restored and it's smooth, so very smooth compared to what it was. For anyone doing this job, the torque on the bolt is a (to me) very low 8nm. I want to thank all of you for your assistance with this, it's much appreciated.
Jasiek071 joined the community
Superb Mk4 Owner's Manual Now Available
What version of MySkoda are you using . Mine still goes to only the digital manual.
- Engine Overheating
