the truth about electric cars
Vorsprung Durch Technik. or Das Auto. Good Tag lines but really for VW Group the slogan should be 'Just do it'. Because they spin stories for years, £17,000 EV,s etc and never get to there. If the can build light and efficient and reliable as in properly designed without fundamental issues or just snagging faults do it. But it seems now if they are going to it needs the assistance from China.
Subwoofer solution in Superb iV (hybrid) with Canton
I contacted @spacelord via a German Skoda forum. He sent me the connector, what a difference in sound, now I have bass in my Superb. Good to have forums like this!
Volkswagon have just released details of their concept electric car, claimed to do 8.27 miles per kWh. This is based on their other concept car the XLintroduced back in 2009 and then the diesel powered 1 litre plug in electric, an early PHEV XL1 which was put on sale in 2015 in Europe only with electric range of 50km but the diesel engine delivered 100km on just 1 litre of diesel. This clearly demonstrates that the diesel-powered cars could be far more efficient and cleaner than they are today and help climate change. Volkswagen unveils the 'world's most efficient electric car' but you can't buy it
I don't even know what this part is called in English, all I know is I need a new one...
047253041A is the part code. https://www.briskoda.net/forums/topic/524557-felicia-with-heat-shield-in-the-intake-manifold/#findComment-5862650 I have remove it many-many years ago. I have covered the exhaust manifold plus installed a heat shield for the Intake manifold.
P0441 Evap: Incorrect Purge Flow 2020 Kamiq SEL 1.5TSi
The idea is that the charcoal temporarily adsorbs the vapours, then releases them to be integrated into normal engine fuelling when engine is running. Lossless and clean.
Wrong suspension springs -help
It seems to me the trouble lies in two areas: 1 The canister should be sited so that no liquid petrol could reach it (short of a rollover!) 2 The logic in the ECU that the purge flow is "incorrect" is too picky - it's effect on engine performance is surely infinitesmal. Personally I really can't see why these "vapours", which would be free of hydrocarbons after travelling through the charcoal canister anyway, shouldn't merely be vented rather than monitored & re- breathed. The irony is that I only went to petrol to avoid the lunacies of modern diesel systems! It seems heads they win, tails they win🤔
Skoda Fabia mk4 2022 Lane Assist
The instructions below were copied from the digital Manual for a 2022 Skoda Fabia Mk4. No option is provided to turn off the Lane Assist feature permanently - it will be turned on automatically every time the car's ignition is switched on. However (as the final paragraph in the instructions says) it is possible to turn off Lane Assist's steering-wheel vibration through the car's infotainment display-screen's settings menu and, once this has been done, steering-wheel vibration will not take place. Lane Assist will still turn itself on every time the car's ignition is switched on, but there will be no vibration of the steering-wheel when Lane Assist 'intervenes'. BURTEQ offers a 'save the settings' memory module for 2021-2023 Fabia Mk4 models https://burteq.com/products/skoda-fabia-4-iv-memory-module and it may be possible to override Lane Assist's automatic activation on ignition switch-on using a diagnostic/code-modifying tool like OBDeleven, VCDS or Carista.
- Issues with Mk 4 1.5 TSI
Felicia PickUp speedometer drive
Ok! Cheers!
F11-79-008-01-HA were ok on my previous 220ps FWD hatch https://www.briskoda.net/forums/topic/485647-bilstein-b6-dcc-shock-absorbers-available-at-last/page/3/#comment-5620484 i can't see huge diff to F11-79-013-01-RA, which is installed on my current 280ps AWD hatch https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/3/#findComment-5854160
Non Return Valve?
My 3 cylinder, CGPA, 12v engine is struggling to start after it's not been used overnight. It turns over OK but coughs and splutters. On second attempt it starts straight away, as it has always done on the first turn of the key up to recently. My VAG code reader does not show any fault codes. I'm wondering if the cause is lack of petrol fuel pressure caused by a failed non return valve. Is there a a NRV in the fuel system? Or could there be an auto choke process that isn't working as it should? TIA
My first car! Skoda Fabia Mk2 SE 12v (CGPA Engine, 2014) keep it in good condition or save the money?
Skoda All-In-One Service Plan
@Evolution13 i bought my Karoq in April 24 (used 6 months old 1,000 miles) oil and filter service by selling dealer. Serviced again in April 25 and April 26, I asked for the Haldex oil change with the April 26 service. I’ll make a note for brake fluid to be done April 27. @Rory as you can see from the above - the services are 6 months out of phase with the first reg anniversary - the first service was 6 months early, free/included in purchase price.
2016 Octavia 1.4 TSI EA211: Brake Servo Vacuum Loss Strictly on Cruise Control / Constant Throttle Uphill
Vehicle Info: Model: 2016 Skoda Octavia Engine: 1.4 TSI (EA211) Symptom & Behavior Symptom: Red brake warning light / error on dashboard, stiff brake pedal (complete loss of vacuum assist). Frequency: Occurs roughly once every few hundred kilometers. Recovery: Braking feel returns to normal/soft after the throttle is released and brake pedal pressed. Trigger Conditions The issue occurs ONLY when driving uphill, and strictly under one of the following two conditions: Maintaining a steady / constant throttle input. Cruise Control is active. Non-Triggering Conditions Driving on flat roads or downhill. Uphill driving with dynamic, varying, or heavy throttle inputs. Engine idle or routine city driving. Completed Diagnostics & Results Check Valve (Manual Cold Test): Line removed completely and tested manually at room temperature. Result: Free airflow from booster side to engine side; 100% blocked from engine side to booster side. Brake Booster (Servo) Vacuum Retention Test: Engine idled for 15 seconds, shut off, and left off for 5 full minutes. Result: First and second pedal presses were soft; pedal stiffened on the third press.
This must surely be your favourite topic on here John 😁 Yeah these were wrong from the start but autodoc has moved it to another level by putting two different springs wrongly into wrong box 🙈
arielvv joined the community
Yeah they are cr*p avoid at any cost. They now have charge back initiated by my bank.... their approach to solving problems is ridiculous. Yes H&R front and rear 💪🏻
'SOLVED' Front-end clunk when load changes
Hi everyone, Quick update: problem solved! The clunk was caused by a slight movement of the front subframe. I replaced all six subframe mounting bolts with new ones and tightened them to the correct specification. Since then, the clunk has completely disappeared, including during braking, acceleration, reversing and direction changes. I’ve now driven the car in different conditions and everything is quiet and stable. So if you have a similar single clunk when the load changes direction, check the subframe mounting/bolts before replacing expensive parts.
It will just be fuel in there, not sediment. A pal of mine had a similar problem on a newish Octy, which was eventually fixed by dealer. They told him this: " They fixed the engine light problem. Apparently it is a known problem on some models, not usually on Octavia, where the vapour cartridge and pipe are undersized. The fix has been to replace these with the newer, larger, design. Done under warranty." I'd never heard anything like it.
Rear left brake dust shield escaped, killed abs sensor?
The only bolt that needs removing as far as I'm aware, is the one behind the cover of the bearing assembly, it's not a front so from looking at youtube/haynes it's a single bolt that gets torqued back up to 180nm plus some degrees too. If it's replacing a knuckle it'll probably have to go to a garage as I doubt I have the kit to do that and would need to replace many bolts too! I haven't looked at the other side honestly, that side is fine and I'm in the school of, if it isn't broken - don't fix it until it is!
Wiring *rear* dash cam?
Most Kits have a trim removal item (usually coloured orange) that you can use to gently pry the edge of the headlining off and tuck the cable under that. I ran the cable from the camera along the top of the rear trim then fed it down the plastic gaiter that hold the electrics for the wiper motor. Then carefully feed it down the "A" pillar. I say carefully because a lot of car have air bags in the "A" pillar and you don't want to disturb or place it in the way of the air bag. If you don't want to chance the "A" pillar then take it as far as the "B" pillar then down the trim (avoiding the seat belt run) along the lower trim beneath the door sill and up behind the side of the glovebox (or side panel) then to the camera itself. And save a hundred quid (plus) ! 😊
Sofo started following Wiring *rear* dash cam?
- Yesterday
How-to Guide to Upgrade MIB2 to MIB2.5
Looking at eBay items it looks like it’s part number dependant and the difference between std and high. Both 8 inch screens that look the same 3v0919606 - black plug - high https://ebay.io/m/mzqBAe Looks the same as 3v0919605a - blue plug - std https://ebay.io/m/YnuE5m So looks like mine will be black plug. I was just assuming by how the screen and buttons looked. Didn’t realise there were 2 different part numbers that looked the same from the front!
Hortiguy started following Skoda Octavia
Hortiguy started following Hellos and Goodbyes
Interesting... in both of our Skoda models, kodiaq & Octavia 3, the 8-inch displays have the blue connector, while the 9.2-inch displays have the black one.
Under no circumstances whatsoever should 0.37kgs of sediment or whatever you wish to call it build up in 3 years and 23K miles, I have had 3 different family VWs, each well over 20 years old when scrapped and never had any problem like that, that canister is supposed to trap vapours, can only imagine that overfilling the tank at every refill might cause this in such a short period, it would be interesting though to see if all all new canisters are of equal weight.
Johngerard started following P0441 Evap: Incorrect Purge Flow 2020 Kamiq SEL 1.5TSi
The correct rear springs for a Sedan/Saloon mk3 Superb is F11-15-007-04-HA. I've lost count how many times I've posted this table now. Don't go by wat these shops r putting on their websites.
