Past hour
- Média display
BillyParker started following Média display
[Octavia vRS 245 - 2019] Constant whistling noise under the rear seat when warm — Fuel pump?
Have you tried to listen when the vehicle is at operating temperature but engine stopped but with ingition ON. The LPFP should be running, if you have the noise like that and it stops as soon as you go ignition OFF, you'll have your answer ;)
Garage Labour Time Per Job....
5 hours in total does seem high especially as they have lifts and should have the proper tools. The fact that the wheel is off centre and pulling slightly isnt right. I reckon something is out of alignment or the steering angle sensor needs recalibrated. Did my old Octavia in around 2 hours but its an old rusty car so nightmare to take apart but didnt affect steering etc. May need a wheel alignment check and if they are ok then steering sensor recalibrated. I would get them to check it over ASAP in case something isnt tight plus depending on whats wrong tyres may start wearing badly. Try full lock left and then right and hold for a few secs each time to see if it helps. Alasdair
Restarting when warm after stop start activated
Hi, thanks for your message, no I haven't, but the issue only occurs when the start/stop system is operating, and then only following frequent restarting in traffic. Apart from then starting a hot engine is never an issue. I am going to have the battery checked, I use the car infrequently and I don't know how old the battery is (pre-owned vehicle). If the battery is in poor condition I'm hoping a replacement will correct the issue. If not, I'll go with your suggested action. Thanks again.
Today
I would not imagine there is a manufacturer today that still makes a car without a rear heating element in the glass ... even the most basic utility vehicle available here that is not a van has them, even basic vehicles like Lada Nivas and UAZes ... Now if instead you refer to the fact that the front is like "instant defrost" across all the glass and not in "lines" starting from the filaments outwards, yeah, I agree ... There are very few cars with the multi-filament option, I remember old Mercedes have that (mine W126 has it), but it is prone after time to "delaminate" which looks awful and for which there is no solution except replacement, which is not longer costly, is just impossible as there are no more glasses available .... ☹️
Heated windscreen, or maybe not?
Well, at least you got the car corrected and with the right equipment! 😉 Heads' up for knowing ... incidentally I found a stone chip on mine, which means will have to face the replacement procedure ... I already told my insurer about it and he said 'no problem' - I got coverage for this in my insurance, but I will have to face the matter as I want a genuine replacement 😬
Remap options for 2023 Mk4 vRS TDI
Pretty sure there’s a lot more than two companies. I know Darkside do it, although it is an additional £350 charge. Not sure if they unlock it in-house or outsource it - you’d have to ask them.
Regular False Tyre Pressure Faults
I actually saw a video on this the other day. I want to say it was TikTok. I’ll have a look - but IIRC the guy was saying that the system was giving false alarms, but that both the ABS sensor and ring were absolutely fine!
Anyone had success requesting a key code to get spare key cut?
What he said. You can get it done by specialists, but the people I know charge basically the same as the dealer anyway. It’s one thing to replicate the physical key blade profile, and another to do the RFID chip.
the rear hatch window normally has heated elements, i.e. demister. i don't know if this was an option in some markets or specs.
Hi Alasdair I'm still waiting to get a full response addressing my query from the garage. Apparently they're looking into it. In the meantime, thank you for your comments. Just to expand on the points you've mentioned. Possible Problems? - On failing the MOT the garage rang to give me the bad news and gave me a quote for replacing both CV boots. I presume at that stage, no attempt would had been made to remove the old CV boots so it wouldn't be known if the job might turn out to be anything other than straight forward. I presume the job did turn out to be pretty straightforward as my invoice shows no difference in the time taken and charged for replacing the CV boot on each side. As per my opening post, the garage didn't mention any difficulties were encountered carrying out the job, either on the day of the repair or since. Number of hours Charged? - The invoice shows 2.50 hours labour charge for each side (Not Both). Travel Time Included? - There wouldn't have been any as the MOT, service and the repairs were all carried out at the same workshop location. Road Test? - I'm not sure. However, since collecting the car it is pulling to the near side and the steering wheel is off centre, neither of which occurred prior to the day. I presume both these things would have been picked up during a road test. I've advised the garage of this in my email queering the invoice price/hours charged. Alignment? - I wasn't informed by the garage of alignment being carried out, and there is no mention of it on the invoice. As mentioned, the car is now pulling to the nearside. Anyway, thank you for your interest Alasdair. I'll update on here when I have more news.
Yesterday
staticshock joined the community
Octavia 2l tdi cupa egr cooler bypass what is needed and how to do it ?
Good effort getting them both from the top! Coolant use has slowed a bit since doing the bypass, but still having to top it up, might just be air purging out. I did run the coolant bleed though so should have got most of it out, but didn’t vacuum fill it or anything
Is yours a hatch? Does the hatch not have a heated rear screen?!
Top mount
I’ll send you a message with link to the manuals which may help.
Did you find out what was up with yours ? I managed doing the bypass from top of engine but deffo needed a 21 or 22mm connector because the coolant hoses where a bit slack on the 19mm but I fastened them on with jubilee clips really tight so hopefully will hold .
I just finished work and the windscreen was frozen…. 1st time using the heated windscreen… wish the rear screen had the same system
Photography Thread
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
Top mount
Made an error when I removed old top mount. I didn't notice which way it was located in regards to the tab where the bearing locates
Top mount
You bolt a piece of 4x2 wood to the anti roll bar drop link connection and jack it up to compress the spring. If you have spring compressors then I assume you can just compress the spring in situ to the same effect. The secret seems to be the positioning of the expansion tool and how you wiggle the brake disc.
Top mount
Thankfully have use of another vehicle. I undone pinch bolt , compressed spring and man handled the shock out. Whats the 4x2 method? As will be doing the other side.
Top mount
I hope you have alternative transport! This is always my fear when doing a job such as this; not having sufficient parts to get back on the road and no way of getting them! Did you split the hub to take the strut out or use the 4x2 method to compress the spring?
oil pressure problem
Oil got expensive recently thanks to Trump.
thsts tomorws job £51 FOR A OIL AND FILTER OUCH
