  2. Today
  3. Pudnig joined the community
  4. Callumholt joined the community
  5. Aaaaand Im late :D One lucky guy got it before me :D U don't have these units to sell? Soon I'm able to DM hopefully.
  6. looks like a standard EFB rather an EFB+ EFB+ models generally provide higher amp-hour capacity and slightly stronger cold-cranking amps (CCA) than baseline EFB tiers from the same brand family.
  7. Yesterday
  8. Thanks for the comments, sorry for the delay in replying but we have been away for a few days. We decided to take the Fabia as it doesn't get alot of use and longer runs - I really enjoyed driving the car which as you say is my wifes. Bit disappointed that it didn’t come with an umbrella given that it was quite expensive with all the extras. I should have checked when we first got the car but hey-ho!
  9. Possibly a blockage in one of the smaller pipes. Sadly if a couple of longer runs don’t resolve it you may need someone who is an expert in DPF’s most garages and dealerships don’t really have a clue Take a look here, he is good https://youtube.com/@orileysautos?si=yawAXYQ-RRBloGeD Don;t get the idea a quick delete will resolve it. Most likely it won’t
  10. I started digging deeper into the issue and noticed that the measured soot mass is increasing twice as fast as the calculated soot mass. That’s where the problem lies: either one of the sensors is malfunctioning, or they need calibration.
  11. It's probably a taxi. My 2020 1.5 TSI petrol does 30k a year.
  12. jimcwestie joined the community
  13. BlueWagon Thanks for the response...... I thought so too. There's always that old adage...'If it's not broken, don't fix it'. I've ordered one controller for £32 odd on ebay....... I will fit it when it arrives and report back. Thx again, BlueWagon for your response. Regards Tom
  14. Thanks for your help both, all sorted.
  15. OccyVRS replied to Mick9879's topic in Skoda Karoq
    What he said ^ I wouldn’t bother doing it every 5k - it’s not remotely a performance engine and with newer oils, you get a fair bit longer before degradation. I just use the standard C5 0W-20 in mine. I spent a fair while thinking about swapping to 0W-30, before realising it didn’t really matter and I wasn’t really bothered. As long as you’re using decent oil (Millers, Castrol, OE, whatever), you’ll be fine. Opie Oils has some good information.
  16. OccyVRS started following Oil Change
  17. Hello everyone, I would like to give feedback to this topic: https://www.briskoda.net/forums/topic/534598-overheating-problem-skoda-superb-year-2018/ Brothers from the Skoda Superb Facebook group in Turkey solved my problem. The problem was the lower bumper grille shutters. They were stuck. I removed the shutters, and now the coolant temperature no longer rises above 90°C under normal driving conditions. It reaches a maximum of 100°C when I drive at 230 km/h with an outside temperature of 26°C. The oil temperature is still quite high, but I think this is either a different issue or simply normal for these cars. Best regards
  18. Rory started following Oil Change
  19. Thank you, but no. I'm in Portsmouth, Hampshire.
  20. Yes they are , Ive ordered off wheelbase a set of oz super t in matt graphite . I reckon 16s for winter will keep an eye for genuines on Ebay , will hang on to stock wheels for putting back on future wise 👌 I think 17s a better compromise . Watch this space 👌👍
  21. Anywhere near N Dorset? Thanks. AG Falco
  22. They were, by 20,000 miles. The schedule is 4 years / 40,000 miles on the spark plugs. I would say especially with a 1.5 TSI ACT 40,000 miles is long enough before replacing.
  23. Lee01 started following Kamiq seat question.
  24. Hi Jackel, Yeah, roads are bloody awful at moment, spend most of your time dodging potholes! I have noticed that they're also quite jarring in the 130 if you go in one... I've been searching for a set of 17" steel wheel to fit winters on but hopefully winters a long way off yet! Are the OEM 18" wheels 7J x ET51 do you know?
  25. Hi. SWMBO is looking at getting a Kamiq but a quick question. Is the seat base angle adjustable on models with electric seats? Thanks in advance.
  26. Personally am not in favour of banning ICE but emissions must be tightly controlled to bring down the number of shortening of life / death due to vehicle emmissons. I am quite convinced the ever increasing economic strength of argument EVs will increasingly have companies, drivers etc choose EVs over ICE. No need to outright ban.
  27. Just back from the garage. Full boroscope inspection done and a wisp of oil in cylinders 1 and 3. Everything as normal otherwise, no scoring. Also compression test done and only cylinder 3 was slightly down but still within tolerance. Small amount of oil in turbo intake pipe but turbo boosting properly. Mechanic says there is excessive suction at the PCV despite a new one being fitted and he can't get his head around it. He's phoning a VAG specialist friend tomorrow for his opinion on where to start with that. He says that is where the oil consumption will be happening. New spark plugs fitted and the car seems to be driving better than before. He says the ones in the car were well past their replacement due date. They were only 60k miles old as well!!!! So hopefully it's not piston rings or turbo.
  28. Re. the tailgate seal is a candidate for leakage. I was amazed at the amount of rubbish I found in the upper reaches esp. near and at both coiled cables in the guttering. It's obvious that Skoda have ignored these two areas.
  29. Understood. Thank you.
  30. RogerC joined the community
  31. The driving mode emphasizes eco-friendliness rather than safety. It resets itself to prevent the use of modes that harm the environment (sport, individual, etc.). It would have been smarter not to reset it if the driving mode is ECO. However, Skoda kept the implementation simple by resetting to normal regardless of the last driving mode. :|
  32. Here's the wheel well after removing the water. Now the leak hunting fun begins.
  33. SbKmOwDA joined the community
  34. legov joined the community
  35. How much engine oil is being used? Have a compression test done on engine.
