Digital cockpit.
This link is to a set of Skoda Fabia Mk4 tutorial videos, including one for the "Virtual Cockpit" (VC) https://www.skoda-auto.com/services/new-fabia-videos The specific VC video is here https://www.youtube.com/watch?v=I4-6j3XseEM A traditional pair of circular dials (rpm and speed) is possible (example below) plus many other variations. The Virtual Cockpit has a 10.25" dimension and a 2025 Fabia could have an 8" or 9" infotainment system (touchscreen). My understanding is that inbuilt 'navigation' is only available with the 9" touchscreen, but that should not prevent separate circular rpm and speed dials being displayed (as shown above) if the car has an 8" touchscreen. My 2024 Fabia came with a hardcopy (paper) Owner's Manual booklet - about 150 pages - that includes 'essential' advice for a new owner. That information is copied into a much more comprehensive (and less handy!) online manual that can be accessed through this webpage. https://www.skoda.co.uk/apps/manuals/Models
Axle stand location
^^^ as above - but on or as near to a subframe mounting-point as possible.
Warrior193 started following Axle stand location
Ocsiral joined the community
Simply So Clever
I heard an interesting one! My B-i-L got a nearly new Sportline Karoq a few months ago. He called me the other day to say his mirrors had suddenly gone 'dark' for a while. I queried whether it was just the internal one but he confirmed it was the external ones as well! Now I'd never heard of external light sensitive mirrors but some googling revealed that some Karoq's do have them. More research indicated that the internal mirror assembly has a rear facing and a forward facing light sensor. If the rear facing one detects its much brighter than the front, then it electrically dims the mirrors!. So why did his do it? Well the sun was reasonably bright at the time but not significantly more bright from the rear. We think we found the reason in the end though!. He had adjusted the cable going from his satnav and we guess that the inline choke module on the cable was blocking light to the front facing sensor!. He's since moved it and it hasn't happened again...
NottsIan started following Simply So Clever
Wheel centre caps.
I buy them on www.skoda-parts.com
Jack25 started following Wheel centre caps.
The rubber stoppers at the end of the wiper(either OEM or Bosch) weren't glued. Turn the wiper upside down, so the rubber part faces you, then using a small screwdriver carefully lift the metal clips holding the plastic stopper. In the same time try to wiggle and pull the plastic stopper. Don't use much force when lifting the metal clips with the screwdriver, but you may need when pulling the stopper because it's usually stuck from the accumulated dirt. Both Bosch and OEM had different type of plastic stoppers, but when you wiggle the specific stopper a little and push and pull gently, you'll see what blocks the stopper to be removed and so which parts need to be lifted.
- Yesterday
vahapylmaz joined the community
Dashcams on Elroq
For the rear-facing camera, did you get the one which plugs directly into the side of the dashcam, or the one which is stuck to the tailgate window with a cable run to the main dashcam? If you got the one which is stuck to the tailgate window, did they do a tidy job with the cable, or is there a big cable loop hanging down between the tailgate and the roof liner?
Mark-Surrey started following Dashcams on Elroq
EuTa joined the community
Head Unit not starting up
Update: OK there seems to be a bit of life left 🤒 buttons have their illumination at night power button causes the backlight to glow faintly (screen still black) little later, the animated logo displays ... ... then shuts down completely will repeat with further presses I'll give it a clean with my can of air, but further information or suggestions greatly appreciated. PS. dirt seems to be coming from a defective exhaust gas temperature sensor. I can get a spanner on it (i.6 has a bit of elbow room) but it isn't budging -- Is it easier to replace that bit of exhaust pipe?
Porucha snimac polohy vack/klik hridele G40
@defsix I replaced the camshaft sensor with a new original part from Skoda and after warming up the engine above 80 degrees, a strange sound came again and the engine light came on. So I don't know what to do next. I'll have the wiring checked and see
The fact you unplugged the cam sensor and the sound went away is your biggest clue.
Simply So Clever
Same here and I had already switched it off!!
1.5 TSI E-tec (MHEV) 12V battery issues
That's good news, mine is a 24 pre-facelift model! I have just 'Googled' the problem and the first response suggests that itis the KESSY system being activated by moving keys thus draining the 12v battery. Apparently leaving doors/ bonnet and/ or boot open whilst cleaning and polishing can also significantly drain the battery !
2 Cylinder Mode…..
AUTODOC, eBay, Amazon, or any specialty stores where do you usually have fewer issues finding the right fit?
Hi Lee, Thanks for sharing your thoughts! You’re right that checking compatibility is important, as even cars built on the same platform can have differences in parts and specifications. The vehicle selection tool is there to make finding the right parts easier, but sometimes it’s worth double-checking details like engine codes, brake disc sizes, and chassis versions before ordering. This isn’t unique to AUTODOC, as fitment data
You did well there, I’ve a set wrongly ordered and I’m well stumped on how to get the rubbers out…….?
- Check the oil level (2019, TDI)
Jim Reire started following Check the oil level (2019, TDI)
Code out Lane assist on a 2026 se Edition
I did it on my 2023 VW UP using OBDEleven. The car has a physical lane assist button on the dash. The car now remembers the last mode it was in. So it is left in the off position, but I can turn it on if needed. ( for the MOT ) Thanks. AG Falco
AGFalco started following Code out Lane assist on a 2026 se Edition
DataPlug app (trip log & refuel detection) – looking for Android testers
Hi all, Does anyone still have a Škoda DataPlug? I’ve made an Android app that uses the DataPlug to log trips and trip data and to detect refuelling automatically. All data is stored locally on your phone, with no account and no cloud. I’m looking for testers for a closed test on Google Play. It runs for at least 14 days. You’ll need a DataPlug and a phone with Android 8.0 or newer. If you’d like to help, please fill in this short form: [LINK] Thanks! Admin note; Briskoda, www.briskoda.net nor the site owner will be held liable for any loss of your data nor will the aforementioned be liable for any malfunction of your mobile devices in the event you go ahead with this app. Outside links are opened at your own risk.
2011 Octavia 2.0TDI 140 CFHC Fuel Filter Confusion
Hi Alasdair, Yes the issue is my canisters part number doesn’t seem to be listed. when you look at the info on the filters especially after market filters they usually say this filter will fit x canister etc hence the confusion as Pete checked my vin which shows a completely different canister part number.
sirkuslindgren joined the community
SOS error call workshop
This thread has been helpful, unfortunately the holding down the red button trick has stopped working in my 2020 Karoq. I went into the local platinum dealership garage today and they were less than helpful. In fact I felt like they didn’t believe me and I was very surprised they had never heard of the problem! My husband had a kamiq with the same issue which was resolved with software update, but when I asked them about this they didn’t even know what software update that could be!! It’s booked in, but I can’t say I have any faith in them after their attitude today. I’m going to write down all the possible solutions offered here to present to them!
beckybipbop started following SOS error call workshop
Fitting rear wheel arch liners - my experience
Yes. All the parts listed were bought from TPS, so they are all genuine parts and part numbers. ''Parts list a follows. Note some new part numbers and some unused parts were delivered. 1S0810971C Inner wheel arch liner left. Now modified note the last letter of the part number is C 1S0810972C Inner wheel arch liner right. Now modified note the last letter of the part number is C 1S08109879B9 Adaptor lower rear left. The adaptors don't appear on the TPS diagram but is listed. 1S08109889B9 Adaptor lower rear right. The adaptors don't appear on the TPS diagram but is listed. N90974701 Screw insert for inner arch chassis holes X 6. ( 3 each side ) N10321301 Screw insert for outer arch chassis holes X 4. ( 2 each side ) N909747701 T25 Torx screw x 18. Only needed 14 ( 7 each side ) as you can reuse 4 from the removed front adaptors.'' All of these parts were used except the last line where I reused 4 screws. HTH. Thanks. AG Falco
Dave1987 joined the community
Hello there
Hello there. I am Ian from down in Sussex by the sea. I have just put a deposit down on a 2015 Skoda Octavia VRS TDI estate as a second car for commuting and providing me with way of getting all my carp fishing gear to the lakes for me. Im looking forward to owning this car as I have had a few cars over the years, including my tuned mini countryman Cooper s auto that was my deceased wife's car, until she passed away recently. I couldn't part with the car as I couldn't bear seeing somebody else driving her car. The Octavia has a DSG gearbox so I am kind of looking forward to driving this car on a daily basis. Please forgive me if I ask any stupid questions.
@defsix Thanks for the advice, I'll try checking the wiring. But I think that if the wiring was bad, the sound wouldn't be so bad when the engine warms up, or could it be related?
- CarPlay crackling issue, software update fix?
Digital cockpit.
Hi lee01, viewing the vehicle tomorrow it has the 8.25 inch touch screen with digital cockpit i know if you have the 10 inch you can have a conventional speed rev counter layout, see what it's like tomorrow. Thanks
Validation of readings from sensor using a separate meter. Resistance check on loom.
