VRS 2025 Key Fob
Hi, my key fob seems not very reactive to the doors also when pointing the fob to open/close the boot lid. Please help. Thanks
daveovrs started following VRS 2025 Key Fob
Steering rack problems...
How did you solve rack issue.
superb5335 started following Steering rack problems...
Software upgrade
@JR RS has done a brilliant guide. Make sure you have a good battery charger connected as a failed battery during this process can be catastrophic.
Binx1310 started following Software upgrade
All In - anyone cancelled shortly after having a service, did you have to pay extra?
I think you have to pay the full balance if you want to cancel.
Brighter Interior Lights
Mine are Phillips cool white w5w led bulbs. Were fitted by previous owner and appear to have a resistor in the light fitting too.
Binx1310 started following Brighter Interior Lights
Kodiaq steering wheel vibration
Do you have any new information?
Android auto not working
Octavia iV estate MY2021 last few days cannot connect my Android phone (Motorola) (was previously no problem). Have tried a different phone (Pixel) - same problem. Both phones upto date with Google software etc Any advice?
JirairD started following Android auto not working
Exhaust Backbox
Not sure I can answer your questions specifically. But I love the solution on this one to keep OEM look with super sprint back boxes
Binx1310 started following Exhaust Backbox
Brake pedal soft but brakes fine. Doesn't pump up, no fluid leak - air in system or master cylinder problem?
Hello, Sorry if this is a tired topic, but I don't really understand it properly. I fell into the trap of consulting AI on it a lot back in May as it would give quick responses to all the details, and at the time it seemed like it was realistic and made sense, but really it doesn't seem to track. So originally my MK1 Fabia had a hard pedal. After a wild goose chase with the servo and its vacuum pipe (which would have become a problem later anyway), we found that the actual cause was a blockage in the ABS pump causing 1 wheel to receive no brake fluid. So we replaced the ABS pump and the pedal was a lot softer and we had much better braking performance. We bled the brakes a few times and replaced the front brake pads as my dad wanted to change them. Then we ended up bleeding them again as we noticed that the pedal was a bit soft. I don't remember at what point we first noticed this, and if any difference was made by the brake pads. It is possible that it was always that soft, but we didn't notice initially as we were expecting a much softer pedal after fixing the old hard pedal. So my Uncle who is a car mechanic who we asked about it, insisted that the brakes were soft because of the new pads and I was just overblowing it because I'm a snowflake or whatever. But I can't see that it would make them that soft, and 1000 miles later the pads should be worn in but there isn't any difference. So originally we assumed it was air in the system and we bled it a load more, but we don't know if there is air in the pump that can only be bled by doing a VCDS bleed. But surely the air trapped in the pump that a VCDS bleed would get out, would not be part of the normal braking hydraulic circuit, until ABS kicks in and extra valves open and the pump has to operate. Otherwise you would be able to bleed it normally and only have the braking dynamics change after an emergency stop where extra air is introduced to the normal circuit. But then I looked more into what I heard about how you are not supposed to use the full pedal travel when doing a 2 man bleed. My dad said he didn't think this was necessary as he had never had that problem with another car. So the AI ended up convincing me that I had damaged the master cylinder seals by bleeding it improperly, which I came to accept, but I haven't yet bought the parts for that job as I keep putting it off as I'm anxious about bleeding the clutch and that becoming a similarly long story. I have already determined which master cylinder and servo mounting gasket I need for that. I just haven't ordered anything. So I've been driving it like this for about 1000 miles (admittedly a lot of them motorway/dual carriageway, but not exclusively) and it stops perfectly fine, just the pedal travel is obviously more than it is supposed to be. I've kind of got used to this now. My dad thinks it might fail its MOT, which is on Friday, for insufficient reserve pedal travel. So I've been told to get the new master cylinder ordered in case we need to change it for a re-test. But today I am looking at other posts on this topic, and it sounds like when the master cylinder seals fail, this is normally accompanied by fluid leaking from the master cylinder either into the engine bay or into the servo. To my knowledge, neither of these have been occurring and the fluid level has not gone down significantly since we last messed with it. I would expect it to go down a bit due to the brakes bedding in. I need to check this again though in the light tomorrow. I hadn't been looking for leaks there before, only at the ABS pump unions. So now I am wondering whether it is the seals after all, or is air in the system. How do I tell? The brakes don't "pump up", which is why I didn't think it was air in the system. Instead, you get a bit of travel, then the pedal gets harder, then if you press on the pedal for a longer time, it very gradually sinks. You can only really do that if the engine is running and the servo is active. The pedal doesn't actually hit the floor, but I don't know if that is possible or if there is a stop somewhere that another part of the pedal hits, or in the MC. So that seems like the MC seals, but why then are you still able to get good braking pressure, and why is there no fluid loss? The master cylinder is the 19 FTE 5615 one if it makes a difference. And the ABS pump is the mid range one that has ASR but not ESP, I think, though I can't remember exactly. Mine doesn't have the ASR button but I think that's because it's an '07 and you can't turn it off. It definitely isn't the ESP one though as we didn't need to do the steering angle calibration when we replaced it. Sorry I've made this really long winded. I'm just trying to include as much information as possible that might be relevant. Elliott
Mattplatt joined the community
MMI in Virtual Cockpit
Anyone looked at this and the possibility of it working with our platform? GitHub youtube Basically mirroring Android Auto / Apple Carplay navigation to the Virtual Cockpit Display This looks the closest option Github
the truth about electric cars
@lol-lol I just watched the Kei car special of the Grand Tour, a bloody good watch and a laugh.
AhmedNa started following Skoda Octavia Mk3 (2013 - 2020)
AhmedNa joined the community
Gearbox Emergency Mode
I promised an update. Haven't forgotten but only heard last week from Skoda Customer Services that after due consideration they will not be covering this under warranty. It took several months to come to this predictable decision. The car has driven perfectly with no problems and no more messages. I still wonder if it's a software glitch and not an an actual physical fault.
UK tries to stop Trump's diesel export ban - BBC News UK tries to stop Trump's diesel export ban ..... That's going to work isn't it. Time to trade in tgMhe older EV as the prices rise i reckon and order an even better one. BBC NewsUK tries to stop Trump's diesel export banJohn Healey said the government is in talks with the US over Donald Trump's threat to stop exports.
almal1 joined the community
The Scenic is very roomy and fits the 6 foot five son in law (getting an ID Buzz this week and getting rid of his VW Caddy as who knows were fuel prices are going to stop going up and even be available to buy at fuel stations) in the front or back of the Scenic. His brother is 6 foot 10 inches so car choice limited, he might be too big perhaps. Yes my 60 /65 KWh was the unusual choice compared to the 87 / 92 KWh version but I was confident it would cope with my Worcester to Heathrow, Liverpool or even Felixstowe business trips. Same for my 5 as I went for the 40 /43 KWh rather than the more common rather than the more common 52 / 55 KWh version. Worked out OK and saved thousands and the lighter cars are more efficient, maybe by only 0.1 or 0.2 KWh per mile. Mg 5 weighs less than 1400 Kg and cannot imagine any car is very much quiter when in motion though I think 18 inch wheels on all models was a bit overkill. Thinking of trying 16 inch all weather or winter tyres especially as we are due a Super El Nino winter just in to 2027.
Adding cruise control to Octavia 3fl
From what I've seen, it is usually possible to have cruise retrofitted - but I don't think it's a simple DIY job, at a minimum involves replacing the LH stalk and coding. Possibly something best left to a specialist.
Columbus MIB3 Nav Maps Update
I think that’s what I did, gonna try the over the air update next longer run
I think the point @skomaz was making is correct for the average EV, not everyone wants a compact car with a small battery. I think it's more likely that even with your car, most would opt for the bigger battery?
Click the bottom option, 'reboot to normal mode' then confirm on the next page
Buy OEM with white color something like this. https://www.ebay.co.uk/itm/147366877216?_skw=Skoda+Superb&itmmeta=01M3MGS4VRQ1ZQNCK33QJETDWB&hash=item224fc01820:g:fZMAAOSwvBVnYRkZ&itmprp=enc%3AAQALAAAA0DKQclQvzFwZQpmMrsO4Luq0ATn9HMUgJm8Do936g5IkiGCi0tA3syrNlg5GVqbYufNuuDgpDVHzcMDpdjtn6c9Vh0wmhBh5GpzISZYGnuDbgZZKPFwZgzMnxC%2BKkcZfI6htehq7KMW9yGFBhufFbM42mwu0Bzznq2ZfSGbD8ejySjicUTf%2FVShQm%2FSZc2op2DtzJOBegXGPoIVGfFotx7n3%2Bed%2Bo3IyOj0EleOaSVjGGw9QTiBhcJcW1z%2F88ZUYYJp08TyXTFQ3XFGaOqAnH34%3D%7Ctkp%3ABk9SR_7N5JCdaA
ile7 started following Brighter Interior Lights
Breakdown In France WOES
Thanks @ Jason_E & @Warrior193 . Still trying to get the car scanned for DTCs. May have some more info in the morning. Sadly the French don't seem to do anything quickly.
Yeah my Scenic is the 60 / 65 KWh version and weights about 100 kgs less than the 87 / 92 KWh version as only two thirds of the battery compartment are populated with batteries. As the torque is quite similar but the weight quite different the acceleration is quite similar. In the new Scenic due out in France this fall the smaller batteried version now has LFP rather than NMC chemistry which is less energy dense so the smaller battery capacity version, 67 KWh, will be similar weight to the 90 KWh but the LFP batteries are much cheaper and don't mind being regularly charged to 100% when the norm for NMC is 80% charge threshold and 100% only occasionally. Both will get the 220 hp rather than use the 170 hp motor mine has. You have the 1.4 TSI and 4x4 with auto or manual ? Liked my 1.4 tsi dsg in my Octy but I think it helped get me nicked for speeding as it slipped in to ECO freewheel mode and crept over 80 mph. In the EV I would have just applied a bit of regen back in to the battery. Br interesting to see which cities follow Paris and hit the vehicles over 2.4 tonnes Gross Vehicle Weight. Cardiff is one and I heard Reading and others to follow suit. My Scenic version slips under at 2340 Kgs. Looks like several Kodiaqs (2s ?) are over the 2.4T threshold and would have to pay the extra city entry fee. Model-Gross Vehicle Weight - kg Max. Towing Weight - Braked 12% - kg Max. Towing Weight - Unbraked - kg Minimum Kerbweight (with driver) - kg Minimum Kerbweight (without driver) - kg Nose weight - kg SE (5 seats) 1.5 TSI e-TEC 150 PS DSG 235/55 R18 100V 2,175 1,800 750 1,659 - 1,739 1,584 - 1,664 100 SE (5 seats) 1.5 TSI iV 204 PS DSG 235/55 R18 100V 2,430 1,800 750 1,911 - 2,075 1,836 - 2,000 100 SE (5 seats) 2.0 TDI 150 PS DSG 235/55 R18 100V 2,300 2,000 750 1,746 - 1,838 1,671 - 1,763 100 SE (7 seats) 1.5 TSI e-TEC 150 PS DSG 235/55 R18 100V 2,231 1,800 750 1,695 - 1,772 1,620 - 1,697 100 SE (7 seats) 2.0 TDI 150 PS DSG 235/55 R18 100V 2,348 2,000 750 1,793 - 1,880 1,718 - 1,805 100 Edition X (7 Seats) 1.5 TSI e-TEC 150 PS DSG 235/50 R19 99V 2,275 1,800 750 1,695 - 1,807 1,620 - 1,732 100 SE L (5 seats) 1.5 TSI iV 204 PS DSG 235/50 R19 99V 2,430 1,800 750 1,911 - 2,075 1,836 - 2,000 100 SE L (7 seats) 1.5 TSI e-TEC 150 PS DSG 235/50 R19 99V 2,275 1,800 750 1,695 - 1807 1,620 - 1732 100 SE L (7 seats) 2.0 TSI 204 PS 4x4 DSG 235/50 R19 99v low rolling resistance 2,402 2,400 750 1,811 - 1933 1,736 - 1858 100 SE L (7 seats) 2.0 TDI 150 PS DSG 235/50 R19 99v low rolling resistance 2,348 2,000 750 1,793 - 1880 1,718 - 1805 100 SE L (7 seats) 2.0 TDI 193 PS 4x4 DSG 235/50 R19 99v low rolling resistance 2,414 2,400 750 1,848 - 1943 1,773 - 1868 100 L&K (5 seats) 1.5 TSI iV 204 PS DSG 235/45 R20 100V (polymer coating) 2,430 1,800 750 1,911 - 2,075 1,836 - 2,000 100 L&K (7 seats) 2.0 TSI 204 PS 4x4 DSG 235/45 R20 100V (polymer coating) 2,502 2,500 750 1,811 - 2,002 1,736 - 1,927 100 L&K (7 seats) 2.0 TDI 193 PS 4x4 DSG 235/45 R20 100V (polymer coating) 2,510 2,500 750 1,848 - 2,035 1,773 - 1,960 100 SportLine (5 seats) 1.5 TSI iV 204 PS DSG 235/45 R20 100V (polymer coating) 2,430 1,800 750 1,911 - 2,075 1,836 - 2,000 100 SportLine (7 seats) 1.5 TSI e-TEC 150 PS DSG 235/45 R20 100V (polymer coating) 2,275 1,800 750 1,695 - 1,807 1,620 - 1,732 100 SportLine (7 seats) 2.0 TSI 204 PS 4x4 DSG 235/45 R20 100V (polymer coating) 2,402 2,400 750 1,811 - 1,933 1,736 - 1,858 100 SportLine (7 seats) 2.0 TDI 193 PS 4x4 DSG 235/45 R20 100V (polymer coating) 2,414 2,400 750 1,848 - 1,943 1,773 - 1,868 100 vRS (7 seats) 2.0 TSI 265 PS 4x4 DSG 235/45 R20 100V (polymer coating) 2,500 2,500 750 1,900 - 2,006 1,825 - 1,931 100 Information regarding tyre technical specifications can be found by visiting the Škoda car configurator here. * Figures for the ŠKODA range, including petrol/diesel and hybrid vehicles. Plug-in hybrid vehicles require mains electricity for charging. Figures for hybrid vehicles were obtained using a combination of battery power and fuel. Figures shown are for comparability purposes; only compare fuel consumption, CO2 and electric range figures with other vehicles tested to the same technical procedures. These figures may not reflect real life driving results, which will depend upon a number of factors including the accessories fitted (post-registration), variations in weather, driving styles and vehicle load. Data correct at 3rd August 2026. Choice of wheels and other options may affect fuel consumption and emissions data. For more information, please see skoda.co.uk/owners/wltp-info or consult your retailer.
Karoq guide - engine advice and infotainment issues?
Hi. I tried to update the navigation system, and I likely had a corrupted file. Now, a software recovery process is running in a loop and asking for the base version—specifically: MHI2_ER_SKG13_K4524 I found the firmware to download on Mibsolution.one. I found the software on mibsolution.one, unzipped it, and put it on an SD card; it enters the recovery procedure, but after installing the program, it encounters an error during verification and restarts. Could someone provide a link where I might download this version from?
2017/17 Skoda Yeti SE-L Drive Outdoor 4x4 DSG 2.0Tdi 150bhp for sale
Registered 30 June 2017 I am the third owner, having bought it in April 2025 at approx 73000 miles from the second owner who bought it as an approved used car from Haysleden Skoda in October 2020 at 36000 miles. Current mileage is just over 88000 which might increase slightly. MOT expires 6 October 2027. Heated leather seats. Heated windscreen. Apple Car Play activated. Full sized spare wheel. Electric folding mirrors. Full service history with numerous backing invoices and various Skoda printouts confirming what was done and when. Timing belt and water pump changed at 51000 miles (May 2022) Haldex serviced in February 2021 and October 2023 (at 62290 miles) Front brake discs and pads changed at 65000 miles Rear discs and pads changed at 66000 miles DSG oil changed at 40000 miles and 82000 miles (Feb 2026) Removable Westfalia towbar. Skoda sat-nav SD card present with recently-updated maps. Full original Skoda owners manuals etc. In excellent condition all round. £9995 ono
Very strange brake feedback - Kodiaq SE
It’s 100% not a brake pad issue. It’s the mild hybrid system causing it.
3000 miles under my vRS belt, a few questions....
Hi All Brand new vRS picked up in July, and with 3k under my belt it's so far exceeding all my expectations, I'm delighted. It's used for regular long haul 200 mile journeys, so the tech and convenience to make it easy to drive are super important to me. With that in mind, after living and experiencing the car, and also ferreting through the handbook, I have a few possibly stupid questions... Pan Roof Blind. Is there a way to make it open/close automatically on unlock/lock like I could on my outgoing Discovery? I often (once a week) get a message at the top of the screen (over a blacked out screen) about the system setting(s) being updated, asking me if I want to save them. But I don't know what setting(s) that refers? All I know is if I press accept, it switches me out of whatever mode I was in, and back into default. I religiously use Waze as my Sat Nav (via CarPlay) including all alerts etc. With that in mind I have no need for the on-board sat-nav alerts, but I can't seem to find the area where I can turn off the in-built Skoda Speed camera warnings which I assume are being triggered by the onboard mapping software? When it triggers, the screen goes black and asks me to acknowledge at the top of the screen, which is annoying because when I'm on the M25 the car is shouting at me twice (once Waze, once on-board) about speed cameras, and also blanking the screen which I have to clear each time. The minimum distance on the ACC leaves quite a large gap (much bigger than cars I've owned in the past). This means cars will often jump out of lane 1 or 2, forcing the car to brake and maintain the another minimum distance. I can make the gap bigger, but seemingly not smaller. Any way to override this or am I stuck with the preset distances? The wireless charger trays don't appear to charge the phone above the level the phone is at when I place the phone (iPhone 15 Pro Max) into the tray. I'm connected to CarPlay and streaming Waze and Spotify, but It'll only maintain the level and not go down, regardless of how far the journey is. If I want to charge it up over the level I seemingly have to plug it into a USB charging post. Thanks in advance
