Past hour
Expert help required
Hi, May be this post will help you: I didn't read it, but the pics let me think it could be very similar to your problem. Hope this helps.
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
barn find felicia pickup.
Fixing/bastardising something is way better than buying a new part. Half a lifetime ago I had a Nissan Bluebird with a near dead engine. While awaiting delivery of a long block, I re-tapped all the shagged threads on the camshaft to keep it running. Reckon I had the only Bluebird in the UK with a camshaft held on by 1/2" BSW bolts 😁 Keep up the good work 👍 G
Khaledfawzy joined the community
Restarting when warm after stop start activated
Long crank or reluctant restarts when engine up to temperature can often be due to failing crankshaft or camshaft position sensors - have you had the vehicle scanned for recorded DTCs?
Warrior193 started following Restarting when warm after stop start activated
Today
Model help
Thank you. This is what I am hoping. I have asked for the VIN number so I can check it out. I know Skoda is reliable but just don't want to start with old parts of that makes sense. I am hoping the Kamiq will serve me well. I have had my current Skoda for 12 years so fingers crossed for this new one too. Then the next one will hopefully be a higher up SUV. I will be honest I preferred the look of the Honda HRV but wasn't overly impressed with the drive. Seemed to struggle with power on the acceleration and was noisy whereas the Kamiq was nippy even with it being 1.0.
- Model help
tonashi joined the community
PhiltheGreek joined the community
- Model help
Latest Software update information (Recommended?)
Mk4
MIB2 update MST2_EU_SK_ZR_P0363T to P0369T – Octavia 3 1.6 TDI (H30) – firmware link needed
https://mibvault.com/firmware/MST2_EU_SK_ZR_P0369T
MrsM joined the community
Stopping chain noise
Since the oil change to 5W 30W chain noise seems to be eliminated. I had plugs and the factory fitted leads replaced. Start up when hot is almost instant and cold start is with less revolutions of the engine. Idle when hot or cold is so smooth and quiet. So happy bunny.
gthr joined the community
ZacDaMan72 changed their profile photo
ARS24 ROCK-8 Subwoofer - Canton replacement
Has anyone here replaced their Canton subwoofer with one from ARS24? The factory sub is a 6.5" dual voice coil 2x8Ω with 200W total - I'm not sure how bad it'll be to run the ROCK-8 D4 (2x4Ω, 200W total). 2x8Ω: https://www.ars24.com/option-rock-8-d8-subwoofer-im-reserverad-fuer-2-x-8-ohm-werks-subwoofer 2x4Ω: https://www.ars24.com/option-rock-8-d4-subwoofer-im-reserverad-auch-beats 2x2Ω: https://www.ars24.com/option-rock-8-d2-subwoofer-im-reserverad-fuer-beats I'm looking at these ones because they fit in the spare wheel quite nicely and use the factory plug so is fully plug & play.
Nimrod2 started following Model help
Model help
Can someone please help. I have purchased a car and only after being given the quote and paying the deposit and then receiving more paperwork did it show I am actually getting a 2024 model. Can someone please advise the difference in the 2024 model, 2026 model and 2027 model. I am concerned the car will have been sat somewhere for potentially 2 years. I was expecting the current year. Shouldn't I have been told if it isn't the current model? It is the Skoda Kamiq 1.0 Tsi automatic SE L edition
Nimrod2 joined the community
Yesterday
Start Stop Stall
P S. in the interim I think I will switch start/stop off. I understand there's a button to switch off the system when setting off on a journey. No more rush hour embarrassment with a green light in front of me, hazard lights flashing and an angry queue behind me!
mjasmin joined the community
Start Stop Stall
Thanks for your reply, useful to know it can be done by oneself, however I'm not too car DIY competent (cars have changed too much during my lifetime) so I might be better having the battery fitted and coded at a service agency. I'll get some prices fitted and coded and x chk cost of just getting a battery and the device you recommend, if it's quite different I might try updating my knowledge! Thanks again.
best way is to top up canister with diesel before putting lid back on, you'll never get any problems with airlocks
Been tightening up on car security, days of nobody steals skoda's are long gone, they steal everything and anything nowadays. Got a disklok, and moved the obd connector to a hidden place with one of these, it leaves a dummy obd in the original place and if scumbag plugs into it, it appears to work but no coding can be done. thinking about fitting a hidden kill switch as well
Rear springs...replace?
If it's a front wheel drive Superb MK2 estate with standard ride height (ie. not lowered ride height or increased ride height), then fitting slightly stiffer rear springs such as two up in the hierarchy should solve the soft rear end problem when the car is loaded. As mentioned in my previous post the upgraded rear springs have OEM part number 3C0511115AF.
- Servicing my serpentine/auxiliary belt, what brands should I get? (CGPA)
I found this video where he prunes using a code reader but says you can just start normally if you don’t have one. He also has other basic service videos on superb which are handy.
Amundsen MIB2 Firmware Update
All check your PMs
Mk4 or 4.5 (facelift) ?
scotthugh3s started following Latest Software update information (Recommended?)
hello hope all is well does anyone have the following: VW Polo 6C 3Q0035874A (MST2_EU_VW_ZR_P0241T) stuck in Emergency Download (Device: cpu Module: cpuboot%1 FileReadError). mibsolution.one is down and MIBVault's P0254T.7z is missing cpu/cpuboot_sec/12/default/Bootloader/init_mibstd2_cpu.dat (SHA1 ad9423fb38ff88c37e3521c58d161785c2ced62e). Can anyone share a working GDrive/MEGA link for MST2_EU_VW_ZR_P0253T.7z / P0252T.7z or that 45KB init_mibstd2_cpu.dat file? currently stuck in red emergency download. i used this file (3.5gb)MST2_EU_VW_ZR_P0254T.7z [21/11/2026 21:44] jessreadingx: https://mibsolution.one website is down and doesnt work also @pab567 @varooom
fclx0 started following Amundsen MIB2 Firmware Update
DCC Slider adjustment option mod
Don't look for them physically, instead use a scanner like OBDeleven or VCDS. That's how u find out part numbers.
fclx0 joined the community
